MAP sensor location
154,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BRITNEY NICOLE BARKER
  • 6 POSTS
I know for sure it is the MAP sensor. But where is it located at? All photos I have seen on line are blurry and sadly no videos are available for the Ion level 3.
Jun 15, 2018 at 10:09 AM
CARADIODOC
  • 34,415 POSTS
What problem or symptom are you trying to solve? Others researching this might have the same issue.
Check the image below
Jun 15, 2018 at 10:27 AM
  • 6 POSTS
Well engine lights comes on with the code. I just needed to know what to take apart to get to the sensor.
Jun 15, 2018 at 2:22 PM
CARADIODOC
  • 34,415 POSTS
Be aware diagnostic fault codes never say to replace a part or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a part is referenced in a fault code, it is actually the cause of that code about half of the time. First you have to rule out wiring and connector terminal problems, and mechanical problems associated with that part. Also, there are over a dozen fault codes related to MAP sensors, and they mean very different things. If you know the exact code number, the definition can get very specific, and the troubleshooting steps will vary. Here is a link to a list of the fault codes:
https://www.2carpros.com/trouble_codes/obd2
If yours is highlighted in blue, you can click the number to go to a page with typical test procedures to possibly avoid wasting money on a sensor.
Jun 16, 2018 at 12:19 PM
  • 6 POSTS
It is the same codes each time the light comes on and from what I read from other people have been saying based on the idle and things it would be that, and maybe, but not too sure the day light/front signal lights turning off for a bit. I just need it fixed by next emissions in December, haha.
Jun 16, 2018 at 12:48 PM
  • 55,758 POSTS
Does the engine seem to have good power? I have seen a partially clogged catalytic converter cause this code.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Cheers, Ken
Jun 19, 2018 at 4:59 AM
  • 6 POSTS
It is running rich and has a rough idle. I know my car if it was that I would have fixed it already having had done it on my first car. It just threw the same code yesterday when my dad was looking at it as well. I just needed the photo map of the engine block because Google is not too helpful.
Jun 19, 2018 at 7:31 AM
  • 6 POSTS
I also know it is not going to be that because I still get good fuel miles both highway and city streets.
Jun 19, 2018 at 7:33 AM
CARADIODOC
  • 34,415 POSTS
I am really confused. There is well over 2,000 potential diagnostic fault codes, and you have never yet shared the exact code number you are getting. How can anyone figure out where to start if you do not know which fault code we are dealing with?
You said, "it is not going to be that, . . . " What are you referring to?
Jun 19, 2018 at 12:50 PM
  • 55,758 POSTS
Also did you see the diagram Caradiodoc offered that shows the MAP location in the above post? Did you check the catalytic converter?
Jun 20, 2018 at 3:23 AM
  • 6 POSTS
I did not need to give the code when I know and have the part. If you look at my post I say I know it is that part because that parts code come up whenever we run the computer through a check system. P0106 which makes the check engine light come on, engine rough idles, and the engine hesitates a bit. So no I did not fail to give a code when I asked originally where a part was located.
Jun 20, 2018 at 6:51 AM
CARADIODOC
  • 34,415 POSTS
P0106 - Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
Thank you for providing that information. This could indeed be caused by a defective sensor, . . . however, . . . if one of us were to tell someone to buy one and replace it, you can be sure there would be swear words associated with our names when it does not solve the problem. If you read through some of the other posts here, you will see the biggest majority of people asking for help with a sensor-related problem already tried a new sensor, and now they are here when it did not solve the problem. That is what I am trying to help you avoid.
As you can see by this code definition, as with all the others, it does not say to replace anything. What it means is the readings from that sensor do not agree with some of the other things the Engine Computer compares it to. For example, manifold vacuum goes real low during periods of hard acceleration, but what if the throttle position sensor is reporting you are at idle at that time? The typical suspect would be a cracked vacuum hose going to the map sensor. To prevent that from becoming a problem, most map sensors now are plugged right into the intake manifold and they do not use a separate hose, but the readings can still be adversely affected by some other vacuum leak.
To add another exciting chapter to this wondrous story, GM developed one of their more common map sensors for use in the mid 1980's, and they had a really huge problem with them, . . . so they sold them to Chrysler, which also had a very high failure rate. GM redesigned them, then had almost no problems at all. Eventually Chrysler used the same design and also had almost no failures. Since then, map sensor failures are very rare. That is why we look at wiring problems first, before we spend our customers' money on parts. Chrysler is the only manufacturer that has never needed or used a mass air flow sensor for fuel metering calculations. It is all done with the map sensor, which is also used to measure barometric pressure before the engine starts running. GM, and most other manufacturers use the mass air flow sensor for their main fuel calculation, and the map sensor is only used as a back-up strategy when needed, and for measuring barometric pressure while you are driving. In fact, a lot of manufacturers call it a "barometric pressure sensor". What that means for us is the symptoms from a failing map sensor vary by car brand. The clue to a failed map sensor on an older Chrysler product is you could keep the engine running as long as the accelerator pedal was moving. Direction and rate of change did not matter; it just had to be moving. That surprised a lot of owners who had their vehicles brought in on a tow truck, then they saw us hop in and drive them into the shop. The map sensor is far less important on other car brands, so often you will just have the elusive fault code, but the engine runs fine.
If you replace your map sensor and the fault code does not set again, we will all be quite happy, but to be sure, pop the old one back in and see what happens. If the fault code sets again, that is pretty good assurance the sensor really was bad. There is a fairly good chance the code will not set again and the old sensor will keep on working. When that happens, it is usually due to a very light film of corrosion that formed on the connector terminals. The scratching action of pulling the connector off and on multiple times creates a clean and shiny area for the mating terminals to make better contact. I used to see that at least weekly when repairing TV's with plug-in modules. Walk across the floor and the brightness would flicker, or one color would disappear. Unplug the module, plug it back in, problem solved! Of course the complete repair was more involved to include sanding the terminals and tightening them, but if the do-it-yourselfer owner bought a replacement module, that would solve the problem for a few months, but it did not address all of the cause. He would be angry for incorrectly assuming the modules kept on failing.
To finish my history lesson on map sensors, the original design used a piezoelectric crystal, similar to that used in a low-end phonograph cartridge. It develops a voltage when pressure is applied to it, then the circuitry inside the sensor amplifies it so the Engine Computer can read it. The problem was caused when people filled the gas tank, then kept on stuffing in more and more gas, then drove a short distance and parked the car, on a very hot day. Every single one of those variables had to be in play. The cold gas would warm up and expand, then the fumes would get pushed through the vapor recovery hose and charcoal canister, into the intake manifold where it found its way to the map sensor. Those fumes ate away the protective jelly the circuitry was sealed in, and they attacked the rubber diaphragm. If it was a cold day, or you immediately drove a good fifty miles or more, or you stopped filling the tank when the pump kicked out, and just finished out the dollar, those fumes did not cause a problem.
The newer design uses a "strain gauge". That is a very long, very thin wire wrapped around a plastic core, then that core is hooked to the rubber diaphragm. When the wire gets tugged on, its length and its diameter change very slightly, but enough that when the circuitry amplifies the change in resistance, it produces a usable signal. While no one actually does this, both designs are so sensitive, they could be used to measure engine speed. Each time a piston takes a gulp of air, there is a momentary tiny increase in vacuum. These sensors are able to detect those slight vacuum changes and count the number of intake events that occur in a given amount of time.
For my parting thought of value, if you have access to a scanner, you might consider watching the readings from the map sensor under a variety of conditions, before you replace it, then compare them to those from the new sensor. Sometimes we can learn a clue to look for the next time we run into this. That clue can even be that the readings from the defective sensor and the new one look exactly the same. Knowing that could give you more confidence when ordering a replacement for the next car.
Please keep us updated on your progress.
Jun 20, 2018 at 12:49 PM
TRYTEN
Engine Mechanical problem
2005 Saturn Ion 4 cyl Two Wheel Drive Manual
where is the map sensor located
Mar 10, 2019 at 3:45 AM (Merged)
  • 75,988 POSTS
MAP Sensor-Good luck 2.0L is on top right of engine above supercharger
https://images.2carpros.com/forum/automotive_pictures/12900_map1_5.jpg
2.2L on top rear of engine behid throttle body at no.3
https://images.2carpros.com/forum/automotive_pictures/12900_map2_4.jpg
BCOLE85202
Where does the map sensor go? cant find any place on the webor the or in a book and nobody seems to know again thanks for your help and its not the redline one.
CJ MEDEVAC
  • 11,000 POSTS
I WENT INTO "MITCHELL I" WITH "ION 2"
SEE IF THESE COULD BE RIGHT
1) 2.0L
2) 2.0L
3) 2.2L
4) 2.2L
LEMME KNOW IF THIS HELPING
THE MEDIC
TAS76
can anyone tell me where the map sensor is located and if replacing this would fix the intermittent loss of throttle while driving and the intermittent idle at 3-4000rpm thanks
SATURNTECH9
  • 30,868 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2003_ion_map_sensor_1.jpg
It's item number 2 in the diagram if you have a 3-4000 rpm idle i would be looking for a vacuum leak when the idle is that high.
