Where is the MAP Sensor located?
78,000 MILES • 1.6L • 4WD • MANUAL
GCHARWAY
What is the location of MAP sensor on the vehicle listed above S-cross engine please?
Thanks
Sep 14, 2023 at 6:38 AM
  • 110,248 POSTS
This vehicle isn't offered in the US, so I don't have manuals related to it. However, I will try my best to help.
The MAP sensor is usually located next to the butterfly valve/throttle body and attached to it or to the intake manifold. Check in that area to see if you can locate it.
Sep 14, 2023 at 12:49 PM
