After replacing steering column the car shuts off while driving
100,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FELISHATRUJILLO29
Where is the MAP sensor located on this car? Also this is an ongoing issue l am trying to fix and find the issue with the car. I already changed the alternator. After the steering column was changed the car started shutting off when driving. I have to turn ignition all the way off before it will start again. What's your intake on this situation? Thank you for your time knowledge.
Feb 7, 2020 at 11:14 PM
If all that was changed was the column and this started, I am wondering if you have an ignition switch issue. Was a used column put into it or was this a new part with or without a new ignition switch?
The MAP sensor is in the left fender area. I included a picture to try and orient yourself.
Clearly if the engine is stalling this could be a MAP sensor issue but here is a guide that covers the other common causes.
Run through this and let me know what questions you have and we can go from there. Thanks
https://www.2carpros.com/articles/engine-stalls
Feb 7, 2020 at 11:56 PM
