MAP sensor location
142,750 MILES • 5.3L • V8 • 2WD • AUTOMATIC
2SOLID2FALL
  • 5 POSTS
I need to replace my MAP sensor on my car listed above SS model.
Oct 17, 2020 at 4:31 AM
STEVE W.
  • 15,409 POSTS
It is pushed into place on the top of the intake manifold just behind the throttle body. Remove the connector and pull straight up with a slight twist. Apply a small dab of oil to the seal on the replacement and reverse the removal process to install the new one.
What is the reason for replacement?
Oct 17, 2020 at 10:37 AM
2SOLID2FALL
  • 5 POSTS
Wasn't there. it was actually on top of the manifold itself.
Oct 19, 2020 at 10:21 PM
