Where is the MAP sensor located on the vehicle listed above limited edition?
May 23, 2018 at 8:18 AM
✓Experienced Mechanic
Hi and thanks for using 2CarPros.com. The MAP sensor on your vehicle is located below the throttle body air intake. I have attached a picture to help locate it.
Let me know if you have other questions or need additional help.
Image (Click to enlarge)
May 24, 2018 at 12:39 PM
AARONDAHL
MEMBER
Picture does not look the same as my motor even.
May 31, 2018 at 7:32 AM
I think this car has a MAF sensor not a MAP. This is what the book shows (below).
Cheers, Ken
Images (Click to enlarge)
May 31, 2018 at 7:36 AM
AARONDAHL
MEMBER
I changed the mass air flow sensor (MAF), but even if it do not have the oil pressure gauge in the vehicle it should still have a manifold absolute pressure sensor (MAP)? I cannot find the location of the MAP sensor. And I cannot find anything online about any of it and to send this to a dealer would be too expensive.
Jun 3, 2018 at 11:35 AM
Is this an overseas car?
Jun 4, 2018 at 3:11 AM
AARONDAHL
MEMBER
I got it from Grand Forks North Dakota, but my friends computer would not hook up to it, so I am thinking it is.
Jun 4, 2018 at 6:12 AM
That could make it a different configuration. Can you take a picture of the engine and bay so I can see what is going on?
