Where is the MAP sensor located?
105,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
NKTLCK
Originally cylinder 2-3 were full of antifreeze, had the head cleaned up new coils, plugs, cam sensors, phasers and timing. Car started fine the started rough idling leaking towards the MAP sensor but can’t locate.
Aug 7, 2023 at 12:27 AM
  • 110,251 POSTS
I attached two pics below to help you locate the sensor. Take a look at them and let me know if they help.
Also, if you haven't already, check for other possible engine vacuum leaks.
Aug 7, 2023 at 12:53 PM
STEVE W.
  • 15,421 POSTS
See the attached for the location and replacement on the top left of the engine.
Aug 7, 2023 at 1:09 PM
