Where is the MAP sensor located?
400,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
HAZZEM
I need help locating the MAP sensor on my vehicle listed above hybrid. I know it should be by the intake manifold. But picture or exact diagram would really help. thank you
Jan 5, 2025 at 10:48 AM
  • 110,251 POSTS
If I recall, you will need to remove the throttle body to access the mounting bolt. The bolt head will be a T25 (torx bit).
I attached two pics below. They were the best I could find. Take a look at them and let me know if you are able to locate the sensor.
Jan 5, 2025 at 2:56 PM
HAZZEM
Thank you so much. The diagram really helped me a lot. I have another question if you don’t mind. The connector to MAP sensor has 4 wires I want to test. I am not sure which is hot wire or ground, or signal wire is there any identification by the color. Thank you for your help.
Jan 16, 2025 at 12:09 AM
  • 55,785 POSTS
The grn/wht wire is the 5 volt reference, the other two go to the PCM , here is the wiring daigrams for the MAP sensor so you can see how it works. Check out the images (below). Let us know if you need anything else.
Jan 18, 2025 at 2:13 AM
