Code 106 for MAP sensor
150,000 MILES • 1.6L • 4 CYL • MANUAL
WILLIAMDAISE
  • 25 POSTS
Have a code 106 MAP sensor circuit out of range or maybe MAP sensor replace. that is the only code. I had the code before.
Oct 27, 2020 at 12:27 AM
  • 110,246 POSTS
There are a few different things that can cause the code. I noted that you indicated you had the code before. What was done? Did it fix the issue for any amount of time?
If you look at pic 1 below, I provided the likely causes of the code. Take a look through them and let me know if you have done anything with what's listed.
I also provided the diagnostics for the code (pics 2 and 3). However, I don't know if you have the test equipment needed. Let me know.
Oct 27, 2020 at 6:31 AM
WILLIAMDAISE
  • 25 POSTS
i didn't know an EGR valve had anything with the MAP sensor. just had a code for a MAP sensor. no testing on it yet. all i have is a launch scanner emu scanner does not have a pid for the Mazda. i was going to the testing i have seen on YouTube other words the MAP valve could be causing the problem. also fuel trims seem normal at idle but it's misfiring. thank you
Oct 28, 2020 at 4:29 AM (Merged)
  • 110,246 POSTS
I need to confirm something. Is this the same vehicle that I replied to earlier regarding the manifold absolute pressure sensor?
If it is, anything that can cause pressure differentials can create an issue.
