Where is the MAP Sensor located?
150,000 MILES • 3.5L • V6
PRETTYGIRL52
Does the car listed above have a MAP Sensor? If so, where is it located?
Jun 25, 2024 at 4:53 AM
  • 55,710 POSTS
Yep, it sure does this car has a MAF sensor which is near the brake master cylinder fluid cap. Here is the exact location in the images below. Check out the images (below). Let us know if you need anything else.
Jun 25, 2024 at 5:05 AM
PRETTYGIRL52
That is the MAF Sensor not the MAP sensor.
Jun 25, 2024 at 5:13 AM
  • 55,710 POSTS
Yep, sorry there is no MAP sensor for this car, just a MAF sensor.
Jun 26, 2024 at 2:22 AM
PRETTYGIRL52
Thanks!
Jun 26, 2024 at 3:53 AM
  • 55,710 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Jun 26, 2024 at 3:54 AM
