MAP sensor nipple broke inside the manifold?
16,500 MILES • 2.2L • 4 CYL • TURBO • 2WD • AUTOMATIC
FILUREN
I got little bit but not all, I've driven it already for maybe 2 hours running time. I'm bumming or does it burn? The engine is a 2.2 Diesel. The nipple broke inside the manifold. It's an 2.2 Diesel?
Sep 10, 2023 at 7:34 AM
  • 55,691 POSTS
Yep, that is a tough one, the engine might process it, or it will get stuck inside the combustion chamber or hold a valve open. You said you have been running it, how does it run? If it's okay, I think you are safe but there is no guarantee because it might be stuck in the intake somewhere. The good news is it is plastic so you might be in luck.
Sep 11, 2023 at 6:44 AM
FILUREN
No, exactly like normal, a little better because of the new MAP sensor.
Smelt burned plastic smell for like 5 minutes. I drove 2 hours today as well.
Sep 11, 2023 at 6:57 AM
FILUREN
But HMAC300
Expert
If it fell into intake and it is not there then do not worry about it, it will go through the engine and not do much harm if any as it is plastic anyhow. Just replace the map and if it has a rubber gasket replace that as well if it does not come with it. Here is the location of the sensor in case someone needs it. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
What another of your experts said, but maybe it's different because of the car.
Sep 11, 2023 at 8:29 AM
  • 55,691 POSTS
Sounds like you are good to go then. Let me know if you have any other problems.
Sep 12, 2023 at 3:02 AM
FILUREN
Hey, I've been driving it now from September - December 1, and haven't driven it now for December 1 to January 15, since I'm outside the country,
Do you think my worries are over or it could still be inside the manifold? Thanks
Jan 11, 2024 at 11:45 PM
  • 55,691 POSTS
it is hard to say but since you have been driving it I would say you are okay.
Jan 13, 2024 at 1:52 AM
