I can’t find it on the car listed above s. We looked everywhere it’s not on top of intake like it shows pictures?
Jan 11, 2021 at 9:06 AM
MOTOR MASTER
✓Experienced Mechanic
Hello my name is Dave
I have checked several data bases and none of them list that code for the car you listed. If you could recheck the code/vehicle information and give us an update we will be glad to help you track down the issue. We look forward to getting your update and thank you for using 2CarPros!
Jan 11, 2021 at 7:46 PM
Yep, the code is for a MAP sensor your car has a MAF sensor. let's re-check the codes. this guide help help with the AMF sensor location in the diagrams below so you can see:
