Map sensor location
75,000 MILES • 2.4L • 4 CYL • 2WD
BRIAN FRONCE
Where the MAP sensor on the car listed above can't locate it?
Oct 22, 2019 at 1:21 AM
SCGRANTURISMO
  • 4,897 POSTS
Your vehicle doesn't have a Manifold Absolute Pressure [MAP] sensor, it has a Mass Airflow [MAF] sensor and an Intake Air Temperature [IAT] sensor, that work in conjunction and provide a more accurate reading to the Power-train Control Module [PCM] then a MAP sensor. In the diagrams down below I have included a diagram of your vehicle and where all the EFI sensors are located. I hope this helps. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Oct 22, 2019 at 1:43 AM
