I have several issue with my 05 hummer h2. First is I would like to remove the rear tire carrier. Its a pain to open the rear of the car with the big swing arm on there, I want to remove it and put the license plate on the back of the car. How do you do this? Is there a step by step process?
I also need to clean out the drain in my sunroof whioch are really clogged? How do you do that?
My brakes squeel like there is no tomorrow and now the ABS and TC traction control light are coming on, what does that mean? do I need new brakes?
Thank you so much for your help....
May 1, 2013 at 4:53 AM
