Manufacturer codes
150,901 MILES
HOUSTON HONDA 1986
  • 6 POSTS
Trying to understand what are readiness codes for certain manufacturers....the codes are 9 in length.... the characters are U and S...
Ex....USSSUUUSU
I'm trying to understand what these codes mean. Are they the manufacturer's blue print or does it mean something else?
Feb 10, 2017 at 4:25 AM
HMAC300
  • 48,601 POSTS
if it's not the vin number then it's a code manufacturers use for the production of car
Feb 10, 2017 at 4:28 AM
HOUSTON HONDA 1986
  • 6 POSTS
It's not a vin number because a vin number is 17 characters....this code is 11, not 9, my mistake. Also, it's only 2 letters, U and S. I am attaching a pic below.
Thanks
Feb 10, 2017 at 4:43 AM
HMAC300
  • 48,601 POSTS
what does it ssay at top of columns where numbers are or at bottom
Feb 10, 2017 at 5:27 AM
HOUSTON HONDA 1986
  • 6 POSTS
Readiness pattern.....
Feb 10, 2017 at 5:34 AM
STEVE W.
  • 15,420 POSTS
S = Set, U = Unset
The chart goes with a table that shows in which order the various monitors run and what the drive cycle is to get each item to run. The attached pics shows a couple versions of the 11 monitors.
Feb 10, 2017 at 6:59 AM
HOUSTON HONDA 1986
  • 6 POSTS
OK... let me get this straight.... those were basically for Toyota.. right..?? Where can I find this information...so I can look at say... Honda... Ford..
GMC.... Chevy....??
Feb 10, 2017 at 7:12 AM
HMAC300
  • 48,601 POSTS
it probably will be in same place on other cars as well
Feb 10, 2017 at 8:22 AM
HOUSTON HONDA 1986
  • 6 POSTS
No... what I'm asking is where do I find the information that you sent me in the above images...??
Feb 10, 2017 at 8:38 AM
HOUSTON HONDA 1986
  • 6 POSTS
Those kinds of charts.... where can I located them for other make and models..??
Feb 10, 2017 at 8:39 AM
STEVE W.
  • 15,420 POSTS
Most of that is in the factory technical service bulletins or in the FSM for particular vehicles. Some makes simply have a single readiness monitor drive cycle. Some of this you can also find in scan tool "help" sections.
Full versions of the above. Just search and you should find the .pdf files.
Toyota - TSB EG003-02
Lexus - TSB EG002-02
Feb 10, 2017 at 12:07 PM
