Manually shifting transmission arm?
223,467 MILES • 5.6L • V8 • 4WD • AUTOMATIC
HAVIC 53
Hello, checking on a problem I'm having with shifting from park to drive or reverse, the truck idles down like going into gear, drive, reverse just seems like neutral only light come on reverse but I've pull cable a loose from transmission and tried hand shift. I do have on 4 stands and a helper to in garage brake as starting it up. help, if anybody knows. Thanks
Jul 19, 2022 at 2:27 PM
  • 55,770 POSTS
It sounds like the parking pawl mechanism has broken or jammed, you will need to drop the transmission pan, be ready for fluid to come out when doing it. This video will show how to drop the pan, and I have included how the parking pawl works so you can see what's going on once the pan is removed:
https://youtu.be/NUOBl4bqtss
Jul 21, 2022 at 1:52 AM
HAVIC 53
Thank you Ken L this is really helpful to know what has happened to cause this problem . Much appreciated Sir.
Jul 25, 2022 at 9:48 AM
  • 55,770 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Can you please leave us a rating? (Copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Jul 27, 2022 at 4:31 AM
