I need to disconnect and remove the drive shaft. I have the repair manual and there are three bolts on each end that need to be removed. On each end, one of the bolts is on the top side and I’m not able to get to it. How can I manually rotate the drive shaft so that I can access all six bolts?
Jan 18, 2025 at 1:35 AM
