Manual Transmission • High-RPM / Unintended Acceleration?
126,600 MILES • MANUAL
ZGACON99
2000 Ford Focus zx3 (Zetec)
PRIMARY COMPLAINT
• The car slowly accelerates on its own while driving with no foot on the accelerator.
• The RPMs ramp up to approximately 4,000–5,000 RPM when the vehicle is moving and the transmission is put in neutral.
• The car idles normally while parked.
• The speedometer works.
• The vehicle does not have cruise control.
CHECKS AND REPAIRS ALREADY COMPLETED
• IAC (Idle Air Control) valve — replaced.
• TPS (Throttle Position Sensor) — replaced.
• Throttle body — cleaned.
• PCV valve — replaced.
• PCV hoses — replaced.
• Vacuum leaks — checked; no obvious leak found.
IMPORTANT PATTERN
The problem occurs while the car is moving, not while it is sitting parked and idling. The high-RPM condition is especially
noticeable when the clutch is depressed and the transmission is placed in neutral while coasting.
Aug 19, 2026 at 5:53 PM
  • 55,542 POSTS
The first thing I would do is check the floor mat on the drivers side, it can get stuck and press the throttle pedal down. IF that is okay, I would check the throttle cable, with the foot off of the accelerator there should be slack in the pedal. next, I would double check the IAC motor electrical connector, here is the location so you can check it out, also I have included a guide to help you as well.
https://2carpros.com/articles/engine-idles-too-high/
Do you have a check engine light on, if so lets get the codes, this video can help.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Please go over these guides and let me know.
Aug 20, 2026 at 5:33 PM
