Manual transmission mode
8,200 MILES • V6 • 4WD • AUTOMATIC
PHGPHD
The vehicle has a CVT, but features a manual shift mode in addition to automatic. I use the manual shift mode for added braking power at stops. Will this frequent switching between manual shift mode and automatic mode cause reliability problem?
Jul 18, 2018 at 11:35 AM
  • 55,694 POSTS
Yes, I would use the brakes and not the transmission. If you use the transmission it can accelerate the wear which in the end will costing you a rebuilt transmission. Brakes are much cheaper and you can do them yourself. Let me know if you want instructions for the brakes?
Here is a general guide:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Jul 20, 2018 at 4:06 AM
PHGPHD
Jul 21, 2018 at 6:21 AM
STEVE W.
  • 15,409 POSTS
I second that. Especially on that transmission which already has a legendary failure rate even with low miles.
Jul 21, 2018 at 3:24 PM
