Manual transmission interchange swap
145,000 MILES • 3.8L • 6 CYL • 4WD • MANUAL
BARNES062490
i have the vehicle listed above JKU with a 3.8 v6 and a manual transmission, (NSG370)
I found a manual transmission (NSG370), out of a 2014 Wrangler JKU with a 3.6 V6, with 50,000 on it.
Will the 2014 manual transmission bolt up to my 2007 3.8 engine?
Dec 4, 2020 at 12:35 AM
Good afternoon,
Yes, the transmission will bolt up to your engine.
Make sure the clutch splines are the same for the clutch.
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
Dec 4, 2020 at 3:05 AM
BARNES062490
The newer bellhousing will not mate with the 3.8 engine.
Dec 9, 2020 at 4:07 AM
WRANGLER4X4
will the transmission from a 1999 wrangler tj sport 4x4 with a 2.5 4cy work in my 1999 wrangler tj 4x4 sport 4.0 straight 6cy? I have a 1999 jeep wrangler 4x4 sport 4.0 straight 6cy and my transmission is bad and im looking for a used one to replace the one i have and the ones i have found the motor's are all 2.5 4cy,will the transmission's work in my jeep?
Dec 9, 2020 at 7:13 AM (Merged)
RIVERMIKERAT
  • 6,106 POSTS
Maybe. You have to see if the bellhousings mate up. The transmission for the smaller engine also may not be able to handle the torque and horsepower from the larger engine.
2CP-ARCHIVES
  • 4,540 POSTS
Will a jeep cherokee transmission fit into a jeep wrangler (Jeep wrangler is year 1998 automatic 4.7L engine)?
CJ MEDEVAC
  • 11,000 POSTS
LOOK UP THE TRANNY---TRANSFER CASEFOR BOTH VEHICLES
LOOK AT PART NUMBERS, PICTURES, ETC THAT WILL CONFIRM OR DENY AN EXACT MATCH
NOW FOR THE BEST PART!
FACTORY SERVICE MANUAL?
WANT ONE?
FOR FREE?
IT MAY ALSO GIVE YOU INSIGHT ON IF THINGS ARE THE SAME---ESPECIALLY IF YOU GET IN THERE AND READ SOME OF THE INTRODUCTORY STUFF!
HAS THIS HELPED?
THE MEDIC
