Manual transmission
138,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MICHAEL BUCKLEY
Changed slave cylinder after getting it all back together bled slave cylinder, i have resistance on clutch but no gears. I can feel it shifting in transmission but no output.
Dec 21, 2017 at 12:53 AM
Good Morning my name is Roy and I will assist.
With the engine off, can you shift through all the gears? If you can, then it is the hydraulics in the clutch. Does the slave have a bleeder screw?
Dec 21, 2017 at 1:02 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If the transmission is actually shifting into gear but no output, than it appears the clutch disc and pressure plate is the problem and it is not transferring the engine torque to the transmission.
Make sure first though that the clutch is fully releasing.
Dec 21, 2017 at 1:20 AM
