manual transmission locked in fourth gear.
121,000 MILES • 3.0L • V6 • 2WD • MANUAL
RDANZL
The transmission shifter is in neutral, l but when I let out the clutch it is locked in fourth gear. If I shift into any other gear and let out the clutch the truck will not move and stalls.
Mar 12, 2016 at 1:50 PM
  • 31,937 POSTS
Sounds as if it is trying to select two gears at once, pull the selector shaft off and see if you can select neutral, if not the box may have to come out to investigate further.
Mar 12, 2016 at 3:51 PM
