manual climate control randomly works
190,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JIRI JANOUS
I have a manual climate control in the vehicle. Switching between functions works only randomly, sometimes it switches, sometimes it cannot switch. I have checked all the connectors and are fine.
Apr 18, 2018 at 9:09 PM
Good morning.
Which air flow is not working correctly?
Apr 18, 2018 at 10:28 PM
JIRI JANOUS
Good evening,
according to the manual is equipped Electronic Touch Climate Control System. Times often happens during the ride that all the options (vent, heater, defog, windscreen, off, max, norm, bi-lev) cease to operate, they can not switch. Sometimes they all start working. Both the fan and the temperature change function normally.
Jiri
Apr 19, 2018 at 5:47 AM
Okay, so it is not manual, it is automatic climate control. that makes better sense.
It sounds like the control head is dropping out.
let me see if I can get some information for you on this.
Apr 19, 2018 at 5:54 AM
There is a programmer behind the glove box that controls all the functions. it is possible that it is malfunctioning. you need a special scan tool to check the system.
Apr 19, 2018 at 6:12 AM
JIRI JANOUS
You were right, there was a relaxed contact on HVAC heater blend door actuator. It is working again. Thank you, yours sincerely, Jiri
Apr 20, 2018 at 6:09 AM
You are welcome. glad you found the issue.
Apr 20, 2018 at 6:13 AM
