Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Drivetrain
Transmission
Symptoms
Engage
Transmission gear first and second not working manual
1995 FORD F-150
35,000 MILES • 5.0L • V8 • 4WD • MANUAL
PATRICIA LUSK BONHAM
MEMBER
Gears 1 an 2 don’t work ,but 3,4, and 5 gears works fine. Manual 5 speed transmission.
Jan 16, 2020 at 11:25 AM
Experienced Mechanic
Good morning,
This sounds like either the shift rail is an issue or something internal has failed.
Most likely the transmission will have to be removed and inspected for the failure.
Images (Click to enlarge)
Mar 24, 2021 at 5:09 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
