Manual four wheel drive not engaging
186,000 MILES • 6.8L • V10 • 4WD • AUTOMATIC
CHEVY FLATBED
  • 14 POSTS
I have the truck listed above super duty Lariat with the v10 manual 4x4 on the floor and locking hubs. when I put it in 4 hi or 4 lo no lights come on and nothing engages besides low range. the front never gets power I checked the hubs they are not stripped and when the back wheels are spinning the front drive shift does not. If anyone has any idea on what this could be I would appreciate the help. thanks
Jan 19, 2021 at 9:17 AM
  • 110,248 POSTS
So the transfer case shifts to low, but the front differential isn't engaged, correct? First, there are a few different differentials that were used. Are there any vacuum hoses running to the front axle?
As far as the transfer case, when in the 4 x 4 mode of operation, torque is transferred from the main input shaft through a high load capacity chain-link belt to the transfer case front output shaft. The front output drive shaft then transfers this torque to the front differential. So, either there is an issue with the linkage or an internal failure.
Is there any noise when you engage the 4wd or anything that may help me diagnose? If the linkage is good and the front axle isn't getting power, then we may need to take the transfer case apart to inspect the chain-link belt. So, let's make sure it isn't an adjustment issue. You may want to disconnect the linkage at the transfer case and try shifting manually to see if you can get it to work. Just make sure the truck is secure before getting under it.
I attached a pic and circled the chain I'm referring to.
Jan 20, 2021 at 11:29 AM
CHEVY FLATBED
  • 14 POSTS
The front axle does not have any vacuum lines going to it and the transfer case does not make any noises at all and does not engage when back wheels are spinning the front drive shift does not. I don't know much about Ford transfer cases but the linkage does work. do you know if there are still vacuum lines ran on the manual transfer case? also there is a plug on top of the case for the light it has 12 volts on both sides when I shoot ground to one side the light comes but doesn't work when it's plugged in. thank you
Jan 21, 2021 at 4:59 AM
  • 110,248 POSTS
The problem sounds internal in the transfer case. When you shift, it should engage. If it is a manual axle (lock out hub) the locking is done at the hub manually. If there is no power to the front differential, it has to be linkage or the transfer case. Whether the hubs are engaged or not, the driveshaft should turn.
______________
There are two different possible shift set ups. I'm going to provide adjustment directions for both. Check them. The attached pics correlate with the directions.
______________
2000 Ford Truck F 250 4WD Super Duty V10-6.8L VIN S
Gearshift Linkage Adjustment-Cast Magnesium Shifter
Vehicle Transmission and Drivetrain Transfer Case Adjustments Gearshift Linkage Adjustment-Cast Magnesium Shifter
GEAR SHIFT LINKAGE ADJUSTMENT-CAST MAGNESIUM SHIFTER
1. Shift the transfer case into 4x4 High.
2. Raise and support the vehicle.
3. Inspect the transfer case shifter assembly (and repair or install new components as necessary) for:
^ visible signs of damage.
^ corroded or damaged pivot bushings.
4. Inspect the shift control rod (and repair or install a new control rod as necessary) for:
^ visible damage.
^ bent or damaged rod.
^ correct control for engine application.
pic 1
5. Loosen the shifter thru-bolt.
pic 2
6. Adjust the gear shifter.
1. Move the shifter base to contact the ramp.
2. While maintaining this alignment, tighten the shifter bolt.
7. Lower the vehicle.
8. Test the system for normal operation.
_____________________________________________________________________________
Gearshift Linkage Adjustment-Stamped-Steel Shifter
Vehicle Transmission and Drivetrain Transfer Case Adjustments Gearshift Linkage Adjustment-Stamped-Steel Shifter
GEAR SHIFT LINKAGE ADJUSTMENT-STAMPED-STEEL SHIFTER
1. Raise and support the vehicle.
2. Inspect the transfer case shifter assembly (and repair or install new components as necessary) for:
3. Inspect the shift control rod (and repair or install new components as necessary) for:
^ Visible damage.
^ Bent or damage rod.
^ Correct control rod for engine application.
pic 3
4. Shift the transfer case to the 4x4 HIGH position.
pic 4
5. Loosen the two transfer case shifter-to-transmission adapter mounting bolts.
6. Verify the transfer case shifter is still in the 4x4 HIGH detent position and hold the shifter handle against the 4x4 HIGH stop while tightening the two transfer case shifter-to-transmission adapter mounting bolts.
Let me know. I have a feeling something is bent or out of adjustment.
Jan 21, 2021 at 1:27 PM
CHEVY FLATBED
  • 14 POSTS
I checked all the components everything looked good nothing was broke or corroded. I believe it is the steel stamped one I tried the adjustment but it didn't change anything. do you think something could be broke inside not making noise? thank you
Jan 23, 2021 at 1:16 AM
  • 110,248 POSTS
I have to be honest, if the lever is moving and nothing is happening, I suspect it is internal. Did this happen all at once and how was it first noticed? For example, were you using the 4wd and it stopped working, or is this the first time this year it was needed and failed to work?
Jan 23, 2021 at 4:49 AM
CHEVY FLATBED
  • 14 POSTS
It was my first time using it on this truck when I noticed it.
Jan 23, 2021 at 7:46 AM
  • 110,248 POSTS
Okay, do you think it was sold to you this way?
Jan 23, 2021 at 10:17 AM
CHEVY FLATBED
  • 14 POSTS
That's my guess now when I test drove it I felt the low range kick in but didn't check the front.
Jan 23, 2021 at 11:02 PM
  • 110,248 POSTS
Low range will still work even if the front differential isn't engaged. When selected, you are simply changing the gear ratio.
Let me know how I can help.
Jan 24, 2021 at 9:37 AM
