Manifold codes come back almost immediately?
137,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Am almost sure this is common, but i never fixed one before. Sometimes a bit of a rough idle when first started then fine. Delete codes and they come back almost immediately after i restart. Codes attaches.
Mar 29, 2025 at 9:41 AM
BHAMDOC1973
  • 2,007 POSTS
any ideas?
Mar 30, 2025 at 6:14 AM
  • 55,562 POSTS
Is this a turbo engine?
Mar 31, 2025 at 5:49 AM
BHAMDOC1973
  • 2,007 POSTS
Yes.
Mar 31, 2025 at 6:11 AM
BHAMDOC1973
  • 2,007 POSTS
Are you able to help?
Apr 1, 2025 at 1:09 AM
  • 55,562 POSTS
The system to lean and the oxygen sensor voltage low is telling us the MAF sensor is bad, I would replace it will a new one and then clear the codes. How does the engine sound while idling, can you upload a short video? Also, does the engine have an exhaust leak? Here is the location of the MAF sensor. Check out the images (below). Let us know how it goes.
Apr 1, 2025 at 2:40 AM
BHAMDOC1973
  • 2,007 POSTS
Changed it and it seemed better. But then after I drove it a few miles there is still a hesitation, and rough idle RPM goes up and down slightly. No check engine light but i scanned it and the o2 sensor code still there. Disconnecting the mad sensor makes it better but the fan stays on high.
Apr 7, 2025 at 1:13 AM
BHAMDOC1973
  • 2,007 POSTS
Is it possible a valve cover gasket leaking can cause such issue?
Apr 7, 2025 at 2:13 AM
  • 55,562 POSTS
I don't think so, with the engine running remove the oil fill cap to see if there are pulses. This can tell us one of the pistons is broken.
Apr 7, 2025 at 4:21 AM
BHAMDOC1973
  • 2,007 POSTS
No pulses. Engine is smooth otherwise, no major engine issues or noises, drives smooth after.
Apr 7, 2025 at 6:11 AM
  • 55,562 POSTS
Did you change out the MAF sensor? Also, what are the Short trim readings?
Apr 8, 2025 at 1:25 AM
BHAMDOC1973
  • 2,007 POSTS
Ya changed it.
Apr 8, 2025 at 1:26 AM
