Manifold
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
DCARLIN
  • 5 POSTS
I recently took off the plenum on the engine to expose the fuel injectors and when I took the plenum off I had fuel sitting in number 5 and 6. my question is, is this normal or not because I'm not sure. please help. I am currently working on it now.
Thank you
Dec 23, 2018 at 4:46 AM
Good afternoon,
No it is not normal. that tells me either the o-ring from the injector to the fuel rail is bad or the injector itself is leaking.
turn the key to on and see where the fuel leak is located. be careful not to crank the motor.
Dec 23, 2018 at 5:09 AM
DCARLIN
  • 5 POSTS
Roy can I do this? I have the battery disconnected. I have all these things unplugged because I'm all the way down at the fuel injectors. I have now just pulled a fuel injector rail is it still okay to turn the key and see if there's a fuel leak?
Dec 23, 2018 at 7:00 AM
not now. too much undone.
Remove the two injectors affected by the leak. if the o-rings are not damaged, replace the injectors.
Dec 23, 2018 at 7:11 AM
DCARLIN
  • 5 POSTS
Okay, I'm on my way to the auto parts store I will do that and then I will put this back together. thank you sir for your help greatly appreciate it. I will let you know when I get those injectors installed. hopefully I'll have them installed by 7 30 745 and I'll hit you back.
Dec 23, 2018 at 7:16 AM
Sounds like a plan.
You are welcome.
Always glad to help.
Dec 23, 2018 at 7:20 AM
