No crank no start
200,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
KGAUGELO BERNARD RAMASHALA
It had a hard start. I did some service and afterwards when I start,i started once and I put it off, then again when I started it nothing happens. Even the engine doesn't crank anymore. what can be the problem?
Oct 3, 2019 at 8:40 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I'm not sure what you worked on, so I will suggest some basic things. Also, this vehicle isn't offered in the US so my technical information is extremely limited.
Have you checked the main fuses in the under hood fuse box? Have you checked to see if there is power to the starter? Is there anything else that is electrical working?
Here are a few links that you may find helpful. Take a look through them.
Here is a link which explains how to check a starter. Follow the directions to confirm if there is or isn't power to the starter.
Let me know if any of this helps or if you have other questions.
Oct 4, 2019 at 11:42 AM
