check engine light never came on. it just shows pix of the lamp.
Oct 7, 2024 at 7:28 AM
✓Experienced Mechanic
a picture of a lamp, which usually refers to the exterior lights or a malfunction in the lighting system. I would turn the lights on and go around the car to see if you can find the bulb that is out, if you need help changing it, please check back in and I can give you instructions.
