Replacement alternator makes loud noise?
112,003 MILES • 4 CYL • 4WD • AUTOMATIC
LA.VERO
  • 43 POSTS
Had my alternator was replaced in Feb 2023 and about 2 weeks ago started making this noise! Please help.
Apr 25, 2023 at 4:45 PM
  • 55,743 POSTS
O' boy, thanks for the video. It sounds like the new alternator is defective and needs to be replaced again. To be sure I would remove the serpentine belt and rotate the pulleys individually. You should be able to feel the rumbling in one of them, try the alternator first.
Here is how the belt is removed:
https://www.2carpros.com/articles/replace-serpentine-belt
Apr 27, 2023 at 7:00 AM
LA.VERO
  • 43 POSTS
If it’s the alternator it would be the 3rd one, I replaced. the 1st one was put in was defective, now this one. Is the problem common for this vehicle?
Apr 27, 2023 at 8:08 AM
  • 55,743 POSTS
What brand is the alternator? did the first one make this noise as well?
Apr 29, 2023 at 3:40 AM
LA.VERO
  • 43 POSTS
Hello, it’s a $200.00 unit and yes, but just not as loud. In my video I posted does the belt look like it’s on right?
Apr 29, 2023 at 3:45 AM
  • 55,743 POSTS
Yes, the belt looks like it is on correctly. I would remove the belt and tun each pulley by hand to help confirm the noise is coming from the alternator and if so may try a different brand or try to get another one.
Apr 30, 2023 at 3:19 AM
LA.VERO
  • 43 POSTS
I spoke too soon the battery light came on, now won't start, so, yes defective alternator again.
Apr 30, 2023 at 3:54 AM
  • 55,743 POSTS
I would get a replacement from rockauto.com that way you wont have to keep redoing the job.
May 1, 2023 at 2:56 AM
