Makes horrible rattle sound in park and reverse
110,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AROSINSKY
  • 7 POSTS
my car makes a horrible rattle sound in park but goes away when I am driving. the noise comes back if i am at a stop sign as well. but again when I am driving the sound goes away. Also my anti freeze seems to disappear but no antifreeze on the ground. Could this be a water pump and timing problem?
Mar 20, 2017 at 11:33 PM
  • 55,849 POSTS
This sounds like a classic broken flex plate problem which is located between the transmission and engine. Use a flash light to see if you can tell if there is any rust colored dust on the flex plate close to the crankshaft. Or raise the car on a hoist to and stand under the car when someone is inside while putting the car in park.
https://www.2carpros.com/articles/rattle-noise
Best, Ken
Mar 23, 2017 at 12:48 AM
AROSINSKY
  • 7 POSTS
I took it to a mechanic and he said what you said, a bad flex plate. I have since had it fixed and the part was $60 dollars and the labor only $300. so on the road again
Apr 12, 2017 at 7:25 AM
  • 55,849 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Apr 12, 2017 at 8:31 AM
