Where is the Main Relay Located?
152,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DILL-11
  • 126 POSTS
Car cranks most of the time then sometimes it makes a sound like ink then return the key it cranks.
Mar 9, 2023 at 7:21 AM
  • 110,248 POSTS
Is there a different way to describe the sound? I'm a bit lost when you say ink. Do you mean you hear a soft click? Could you hear the starter relay engaging?
Mar 9, 2023 at 1:19 PM
DILL-11
  • 126 POSTS
It sounds like a hissing sound.
Mar 9, 2023 at 8:52 PM
DILL-11
  • 126 POSTS
Do not hear the starter relay engaging.
Mar 9, 2023 at 8:54 PM
  • 110,248 POSTS
Could the starter be spinning but not engaging with the flex plate to turn the engine? If it is just the starter motor spinning, it could sound like hissing.
Is it possible for you to record what you hear and upload it for me to hear?
Mar 10, 2023 at 1:12 PM
