Car cranks most of the time then sometimes it makes a sound like ink then return the key it cranks.
Mar 9, 2023 at 7:21 AM
✓Experienced Mechanic
Is there a different way to describe the sound? I'm a bit lost when you say ink. Do you mean you hear a soft click? Could you hear the starter relay engaging?
Mar 9, 2023 at 1:19 PM
DILL-11
MEMBER
It sounds like a hissing sound.
Mar 9, 2023 at 8:52 PM
DILL-11
MEMBER
Do not hear the starter relay engaging.
Mar 9, 2023 at 8:54 PM
Could the starter be spinning but not engaging with the flex plate to turn the engine? If it is just the starter motor spinning, it could sound like hissing.
Is it possible for you to record what you hear and upload it for me to hear?
