Main bearing cap bolts?
7.4L • MANUAL
NTCCANNON218218
I have a 454 BBC Mark 4 1990 with four bolt mains, I am ready to take it to a machine shop, how do you make sure the bering cap bolts get put back in the correct hole they were taken out of. I know they are different lenghts, so top and side are easy, but I have been told the exact bolt must go back in the same hole. is this true?
Sep 9, 2026 at 6:26 PM
STEVE W.
  • 15,414 POSTS
See the other answer please. The short version is they don't have to be kept in the same holes, the caps do.
Sep 9, 2026 at 7:57 PM
NTCCANNON218218
Sep 10, 2026 at 6:44 AM (Merged)
STEVE W.
  • 15,414 POSTS
The caps must go in the correct positions but the bolts don't need to be kept in specific spots. However I would suggest replacing the originals with new bolts like ARP or similar. 1990 was a while back and those bolts have seen a lot of heat cycles and tension stretch. I would also replace the head bolts and the connecting rod bolts as well for the same reason. Especially if you are planning or doing performance upgrades.
