Where is the MAF sensor located?
134,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
WONDERWEB
There is not a Mass Air Flow sensor located after the air filter and before the throttle body. Where is it located? Thank you
Jul 14, 2021 at 3:02 AM
COLBY_STEPHENSON2000
  • 32 POSTS
This vehicle doesn't have one, it uses a MAP sensor. Manifold Absolute Air Pressure. It is located on the right side of intake manifold. Here is a picture of your intake manifold and I circled the MAP sensor. It is small and 1 10mm bolt holds it in. I have had no luck trying to clean those. I just replace them.
Jul 14, 2021 at 4:24 AM
WONDERWEB
Jul 15, 2021 at 2:26 AM
  • 32 POSTS
You're welcome.
Jul 15, 2021 at 2:51 AM
