Does the MAF sensor have a gasket?
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
STARLORD1976
  • 173 POSTS
On my MAF sensor and in the picture, it shows sensor with a gasket, but when I call auto part stores, they say it doesn’t have a gasket.
May 1, 2022 at 2:09 AM
  • 110,246 POSTS
It doesn't have a "gasket" in the sense of a paper gasket, but instead, it has a rubber o-ring.
I'm not sure if they are confusing that with what you are referring to.
If you look below, I attached the directions for the removal and replacement of the MAF sensor. It indicates there should be an o-ring. Otherwise, there would be an air leak, and the MAF signal would be off.
Keep in mind, the o-ring is likely to stay in the air intake box. Maybe because of that, most new ones don't come with a new o-ring.
The best thing to do is remove your sensor and see if there is one on the MAF or if it is part of the air intake box.
I attached the directions below for you if needed.
May 1, 2022 at 1:51 PM
