Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Mighty Max
Engine
Wiring
MAF Sensor wiring diagrams?
1994 MITSUBISHI MIGHTY MAX
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
MEMBER
Need to know the vehicle listed above, Mass Airflow Sensor spec's on the wiring connector?
Aug 10, 2022 at 3:43 PM
Experienced Mechanic
Here are the engine wiring diagrams which included the MAF sensor and I have included a guide to help you check the connections.
Images (Click to enlarge)
Aug 11, 2022 at 3:19 AM
PACIFICISLANDER
MEMBER
I need the specs of the connector pins/terminals such as the 5v/12v/MAF signal wire/ and others on the 7 pins.
Aug 11, 2022 at 6:31 AM
Sure, here you go. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Aug 12, 2022 at 3:23 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
