MAF sensor?
190,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WILLTCARTER87
I have a blue streak MAF sensor. It is 5 pin out got at auto parts store O'Reilly's. My car listed above is an LX sedan. It has four wires I think the old MAF sensor used to be a 4 pin out can I hardwire the 5 pin out to work ECU has purple blue and tan and grey that go to MAF. Please help
Dec 7, 2024 at 10:03 PM
STEVE W.
  • 15,401 POSTS
Not the correct part and they are not able to be interchanged as they are internally different. Your car requires part number 379805BAA01 which is the 4-wire part. Also, on Honda and Toyota the aftermarket sensors tend to cause other issues because they are not exactly like the OEM parts. I have seen lean and rich codes as well as odd sensor codes from new aftermarket parts that vanished as soon as an OE part was installed. The MAF is a critical component in the system so trying to use the wrong part isn't going to work.
Dec 8, 2024 at 12:06 AM
