MAF connection wiring diagram?
212,000 MILES • 4 CYL • 2WD • MANUAL
PRISSYPANTS
i have pink brown green and two black wires coming from the wiring harness my connector that I bought has all five black wires how do I know what to connect to where please help
Jan 21, 2026 at 11:40 AM
STEVE W.
  • 15,380 POSTS
That is common with replacement pigtails as it allows them to fit multiple makes and models. The easiest way is simple matching. Verify that the new pigtail fits the MAF sensor. Now look at the old connector and orient them both the same way. With the clip on the same side. Now pick a wire on the old connector and match it to the same pin in the new connector. Pin one has nothing, pin 2 is green, pin 3 is black, pin 4 is pink, pin 5 is brown and pin 6 is black. The two black wires go to the same connection. The connector or the MAF should have the numbers on them.
Jan 21, 2026 at 1:09 PM
PRISSYPANTS
im so thankful for ur response. i will go out directly and try this. you are amazing
Jan 21, 2026 at 10:49 PM
STEVE W.
  • 15,380 POSTS
Just make sure the wires are in the correct places by matching them to the originals.
Jan 22, 2026 at 11:45 AM
