Hello, anyone know what I should do to fix this car? :'(
I changed idle control valve, oxygen sensor, EGR, MAF, cleaned clogged pipes and throttle body. Reset ECU.
Cleaned MAF with MAF spray and also old MAF.
Checked wiring and ECU connection for water damage.
Checked pipe for air leaks, used tape make connections tighter fit.
Car works with MAF disconnected but this is not allowed in UK.
Car also works when revs kept above 2,000.
What else can I try?
Feb 7, 2020 at 5:28 AM
