Lukewarm Cranking Issues?
180,000 MILES • 5.4L • 4WD • AUTOMATIC
JASON52379
I recently had a lean code. I replaced the PCV elbow and connector, and I cleaned the MAF sensor, and the code went away, and the fuel trims are in the single digits. Ever since I cleaned the MAF sensor, though, the truck has to crank for a second before it fires up when it is lukewarm. It only happens when it sits for an hour or so after running.
Could this be related to the MAF sensor cleaning, or am I better off starting with the crankshaft or camshaft sensors.
Nov 20, 2026 at 6:25 AM
