Lukewarm air on passenger side?
167,000 MILES • 3.5L • AUTOMATIC
TAREZ COLBURN
I have recently replaced my heater core and after a couple weeks my passenger side has started blowing lukewarm air again.
Oct 7, 2023 at 12:37 AM
  • 55,658 POSTS
With winter on its way the heater is definitely needed. If the passenger side blend door actuator goes out it will cause this problem, I assume the driver's side is hot, correct? Here is the location of the blend door actuator so you can swap it out.
The Dual Zone heating and A/C system has two blend door actuators, one for the driver side and one for the passenger side.
Here are both the drivers' side and passenger side actuators so you don't get them mixed up. Also, you will need to remove the glove box and some ducting. Check out the images (below). Please let us know how it goes.
Oct 7, 2023 at 1:47 AM
TAREZ COLBURN
My blend door actuators are working just fine. Is it possible the problem could be my thermostat ?
Oct 14, 2023 at 1:25 PM
  • 55,658 POSTS
Yes, it could be, is the driver's side hot or lukewarm as well? With the engine warm grasp, the heater hoses going into the firewall to check the heat level. Also, check the coolant level of the system when it is cold only. If the heater hoses are not hot here is how to change the thermostat out. Please check out this guide as well:
https://www.2carpros.com/articles/car-heater-not-working
Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car.
Oct 15, 2023 at 3:51 AM
