Lug nut, was cross threaded, will this cause any damage?
39,000 MILES
PGORDONJR
AutoNation is where I get oil changes, for years. I went yesterday and was told the car is in pristine condition; however, a lug nut is cross threaded. I got express service as no mechanics were on site, rep advised I’d be good to go until next visit in approx 6 months. I just want to confirm there is no real hazard, etc.
Jan 15, 2023 at 10:21 AM
STEVE W.
  • 15,410 POSTS
No real hazard but if you needed to get that tire off due to a flat you likely couldn't. To repair it you will need to get that lug nut off, then replace the wheel stud in the hub and use a new lug nut. Basically, similar to this, however you may not need to remove parts depending on which axle it is on and how much clearance there is.
https://www.youtube.com/watch?v=LSZ8P0wrQX8
Jan 15, 2023 at 6:46 PM
PGORDONJR
Thanks for the info! I was thinking my wheel would come off. So, I can wait until my next oil change in July to address that. Again, I just want to make sure it’s not urgent.
Jan 15, 2023 at 8:48 PM
STEVE W.
  • 15,410 POSTS
Yes, you can wait a bit. The wheel won't come off, as a matter of fact with a lug nut cross threaded it's going to be serious work to get it off.
Jan 16, 2023 at 2:50 AM
PGORDONJR
Thanks, Steve! You are amazing. I am grateful for your promptness and expertise.
God Bless You! :-)
Jan 16, 2023 at 2:55 AM
STEVE W.
  • 15,410 POSTS
That is what we are here for. Thank you for using 2CarPros. Please return anytime with your automotive questions.
Jan 16, 2023 at 3:51 AM
