lt & rt license plate and 3rd brake lights out
2006 MERCEDES BENZ CLS550
84,000 MILES
TBERTELSMAN
lt & rt license plate and 3rd brake lights out. Also trunk release inoperative. Is this a fuse problem? If so which fuse? Or is there a rear signal activation module (SAM) that needs work? BTW: My car is a CLS500 not a 550.
Thanks.
Jul 12, 2013 at 12:24 AM
  • 31,937 POSTS
Start with checking that the globes are ok, sort that one out first.
Jul 12, 2013 at 10:49 AM
TBERTELSMAN
I have not checked the light bulbs yet. I thought it was a fuse problem first because all 3 lights went out at the same time. To coincide with the lights being inop, the trunk release does not work either. The only way to get in the trunk now is by using a key. Thanks.
Jul 12, 2013 at 2:11 PM
  • 31,937 POSTS
They will run different fuses so check lights first and i will look into the other issue.
Jul 13, 2013 at 2:45 PM
