LS swap question on power steering hoses?
180,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
SNYDERMAN
  • 6 POSTS
Hi, I put a 2005 6.0 LQ4 in my car listed above. I'm having issues finding the right fittings to connect the power steering pressure hose. I found a fitting on Amazon the goes into the back of the pump, but it has a female 3/8" inverted flare where the hose is supposed to connect. My hose is a 3/8" female regular flare. So, I'm trying to go from 3/8" female inverted to 3/8" female regular flare. Cannot find a fitting or fittings to make the connection. Any advice you can offer?
Mar 25, 2024 at 11:30 AM
STEVE W.
  • 15,415 POSTS
Look for a shop locally that rebuilds hydraulics and makes hoses. They can make you a line with the correct fittings on each end without using adapters. Or check with Summit racing. Their tech line crew are really good at finding odd parts.
Mar 25, 2024 at 8:36 PM
SNYDERMAN
  • 6 POSTS
Thank you, Steve! I think I may have found the right fitting - Gates 350040. Now I'm hearing the LS style pumps have different pressure than the old-style pumps. Do I need to be concerned with that?
Mar 25, 2024 at 9:05 PM
STEVE W.
  • 15,415 POSTS
Most pumps run 1,200-1,500 PSI on a conventional steering box, on a rack they run a bit lower. I wouldn't worry a lot, if the pump you have was set to a lower pressure it will just mean the 67 won't be a one finger no feedback system like it came from the factory.
You can always swap the pump out if you like.
Mar 26, 2024 at 1:24 AM
