LPG Fueling System
48,000 MILES
LEMICKA
  • 5 POSTS
Can an originally Japanese manufactured car with an LPG fueling system be converted and turned into a normal Petrol fueling system?
Jul 8, 2019 at 5:48 AM
Hi Lemicka,
There are all kinds of conversion kits to convert a car to LPG but I am not finding many to change them away from it let alone when they are built this way from the factory.
What I would suggest is to contact a dealer and ask them if they have a kit to disable the system. Usually when an OEM makes one of these vehicles, they have a way to convert back and forth. If they don't allow it then they will be able to tell you that as well.
Unfortunately we are not dealing with a "bolt on" system that someone added and can be easily removed. This system has been designed into the vehicle and so it is not just easily unbolted. Sorry I can't be of more help.
Jul 8, 2019 at 6:13 AM
STEVE W.
  • 15,409 POSTS
I would think you are stuck with LPG. To convert it to petrol you would be replacing the entire fuel system from removing the LPG tank, installing a petrol tank and running new lines and EVAP system along with the parts needed on the engine for the conversion. That is a different intake and injection system along with a different ECM and some of the wiring harness. If you wanted to do it the easiest way would be to find a running version of the car in petrol and swap out all the pieces. However once converted it may not pass MOT/inspection as it now isn't the vehicle that matches the VIN.
Jul 8, 2019 at 6:27 AM
