Lowering springs, do I need to add camber caster plates?
184,000 MILES • 3.8L • 6 CYL • 2WD • MANUAL
STEVOAMBER
If I lower my car 1.5 inches, do I need to add camber caster plates?
Jul 31, 2022 at 11:35 PM
  • 55,781 POSTS
If it is only 1 and 1/2 inches you should be okay, once the lowering is done take it to an alignment shop and if they can't get it within specs you will need to add the plates. Please let us know if you need anything else to get the problem fixed.
Aug 1, 2022 at 7:09 AM
