Lower radiator hose replacement
61,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JABRAMO
  • 49 POSTS
How do I get to the lower radiator hose to remove it?
Aug 16, 2020 at 4:04 AM
I attached the process from the manual. You should not need to remove much in order to get to it. It may be needed to get to it from underneath. Most all these processes assume you are working at a shop with a lift so they take that for granted.
Let me know if you still need more info and we can see about getting more details. Thanks
Aug 16, 2020 at 4:24 AM
JABRAMO
  • 49 POSTS
It’s a pressurized system and I can barely see it. is there anything I can remove to get to it easier?
Thanks
Aug 16, 2020 at 4:32 AM
Are you looking from the top or the bottom? I would suggest looking from under the vehicle and then seeing what you may need to remove. Unfortunately it is one of these repairs that you are going to have to just look at what is in your way and remove it. I have not done one on a Malibu in a couple years so I don't remember taking anything special off.
Also, you are going to want to make sure you depressurize the system before you attempt this otherwise it is going to spray coolant all over.
Aug 16, 2020 at 11:56 AM
JABRAMO
  • 49 POSTS
Thanks much appreciated.
Aug 16, 2020 at 6:54 PM
JABRAMO
  • 49 POSTS
How exactly do you depressurize the system? do you mean open the reservoir cap?
Aug 16, 2020 at 7:01 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a basic tutorial on how to replace radiator hoses:
https://www.2carpros.com/articles/replace-radiator-hoses
The question you asked was if the system is pressurized but mainly when the engine is running and at operating temperature is what you need to be aware of. When the engine is cool and not running is when you should perform this repair.If you want better access to the lower radiator hose you might consider removing the lower air baffle underneath the radiator.It is just a few plastic screws.When the cooling system has cooled off you can then remove the radiator cap to remove the residual pressure without worry of burn. I've attached a picture below of the air deflector-baffle.Hope this helps and thanks for using 2CarPros.
Aug 16, 2020 at 11:58 PM
JABRAMO
  • 49 POSTS
Thank you, that was exactly what I needed to know.
Aug 17, 2020 at 12:05 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Let us know if you have any further questions on this issue.Just for you to know..Your vehicle requires DEX-COOL engine coolant as a GM requirement. See picture below.Hope this helps and thanks again for using 2CarPros. We hope you will use our site again in the future.
Danny-
Aug 17, 2020 at 12:35 AM
JABRAMO
  • 49 POSTS
Got it.
Aug 17, 2020 at 12:54 AM
Thanks Danny for jumping in.
Let us know how you make out and if other questions come up. Thanks
Aug 17, 2020 at 1:48 AM
JABRAMO
  • 49 POSTS
Okay.
Aug 17, 2020 at 1:52 AM
DANNY L
  • 5,648 POSTS
Hello again.
Keep us updated and let us know if you have any further questions on this issue.Thanks again for using 2CarPros.
Danny-
Aug 17, 2020 at 8:17 PM
