Lower control arms
250,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ADAM COWSERT
  • 41 POSTS
Well I just replaced the lower control arm on my 99 Jetta and now when I drive it there is a horrible grinding noise, like it's rubbing against a sharpening stone
Oct 14, 2021 at 3:46 PM
This is normally due to metal on metal when the wheel is turning.
Can you get a recording of this noise and that will help identify it?
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
However, what I would do is lift the vehicle on jack stands so that you can spin the tires and look for anything that is rubbing the wheel. Specifically, the backing plate and rotor.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please run through this info and let us know what questions you have and what you find. Thanks
Oct 15, 2021 at 8:05 AM
ADAM COWSERT
  • 41 POSTS
When it's up in the air it doesn't make that sound but when I put the tires back on, lower the car and back up out of my driveway and proceed to go forward it makes the grinding sound. then it will stop for a second when I turn my wheel but then start back up when I get it straight again and it feel really loose in the front end.
Oct 15, 2021 at 10:16 AM
  • 110,251 POSTS
I suspect you had the axle removed. Are you certain it is fully seated back into the transmission? It could be rubbing on the rear of the hub assembly causing the noise. When you torqued the axle nut, was the vehicle still off the ground?
Is it loud enough that you could record and upload for me to hear?
Also, check and make sure the backing plates behind the brake calipers are not bent and rubbing against the rotors. Make sure things like the stabilizer links are connected and nothing is touching the sway bar itself. (I highlighted what I'm referring to in the pic below.
See pic below.
Oct 15, 2021 at 11:54 AM (Merged)
ADAM COWSERT
  • 41 POSTS
Well, I didn't take the axles out at all and now I have taken off the splash shield on both side and it's still rubbing but mostly when I'm braking and turning, I am really starting to seriously dislike this car.
Oct 17, 2021 at 7:41 AM
I am thinking if we can get that video, we can confirm this but if with the load off the vehicle or turning the wheels, it seems like a wheel bearing.
Clearly a bearing normally starts making noise when it spins fast enough so I am concerned that it starts making noise right away. Hence the reason I think we need to hear it.
Otherwise, this would have to be something rubbing the rotor, but I would think you could see that which is why I am thinking it is a bearing.
Oct 17, 2021 at 10:41 PM
ADAM COWSERT
  • 41 POSTS
I figured out what it was.
Oct 19, 2021 at 11:49 AM
Oh. That is great. Do you mind providing details on what it was and what you did if it was something unique so that we and others can benefit from what you found?
Thanks for letting us know.
Oct 20, 2021 at 9:05 AM
ADAM COWSERT
  • 41 POSTS
It turns out that it was the ball joint rubbing against the rotor, I didn't know you had to have those things exactly where they were before.
Oct 20, 2021 at 2:55 PM
Okay. Thanks for the info. That is great. Make sure you have an alignment done now or you will chew through tires quickly.
Thanks again for using 2CarPros.
Oct 21, 2021 at 12:26 AM
