Lower brake lights not working
277,418 MILES • 6 CYL • 4WD • AUTOMATIC
SCINNA
The lower brake lights stopped working but the top one works fine. I have checked all the fuses and bulbs. Checked the wiring down by the the brake pedal and do not see any loose connections. Does anyone know what the possible problem can be?
Apr 20, 2018 at 10:44 AM
HARRY P
  • 2,292 POSTS
Most likely it is a bad ground. Trace the ground wire for those lights and see how it looks and feels. You can pretty easily reground the wire. If that is not the problem, then the problem is likely in the lead wire. Either way, I believe it is a wiring issue. Here is a guide on checking wiring: https://www.2carpros.com/articles/how-to-check-wiring
Let us know what you find.
Apr 20, 2018 at 11:58 AM
WRENCHTECH
  • 20,760 POSTS
Since the tail lights and license plate lights share the same ground with the brake lights, it is unlikely to be the cause. If your truck is equipped with a lamp out warning feature, that is a module inline with the feed to those two lights.
Apr 20, 2018 at 12:05 PM
