Low Whirring sound when engine is idling?
209,000 MILES • 4 CYL • 2WD • MANUAL
FLINTEVAN25
When the car is turned on and idling, there is a low whirring sound that is coming from under the hood. It appears to be something in the middle area near the actual engine.
Jan 24, 2023 at 2:33 AM
FLINTEVAN25
the noise also seems to get quieter when the engine warms up.
Jan 24, 2023 at 2:39 AM
FLINTEVAN25
i have also noticed a light tapping sound, as if something is spinning weird. maybe a belt or fan?
Jan 24, 2023 at 5:10 AM
  • 110,248 POSTS
The idea that it is coming from approximately the center of the engine compartment and gets quieter when the engine is warm sounds like it could be related to an engine vacuum leak.
Do me a favor. Do a quick inspection of the engine vacuum hoses along with the air intake tube, and intake manifold. Make sure nothing is disconnected, damaged, or dry-rotted.
Also, if it is possible for you to record it and upload it for me to hear, it will be helpful. In addition, here is a link that explains how to locate and repair an engine vacuum leak:
Jan 24, 2023 at 6:55 AM
